I have a splash back where one of the fixings has come loose as the plug has come out of the drilled hole. Is it possible to fix this without taking the whole of the splash back off the wall as would be difficult? I was thinking of using a longer screw to screw into the breeze block or glueing from inside of plug but not sure if either would work??? Or possibly just using a larger screw? Not much weight involved, just holding the splash back tight to the wall.
Rawlplug Wet-N-Fix Repair Solution Pads you could try. Trust me. Only ever use Fisher raw plugs. Harder plastic. Better design ect
Give a larger screw a go first and see what happens, put it in with a combi drill on fast and see if it catches and starts to bite
Hopefully it’s not a glass splashback then ? Wack in a larger screw using a combi drill on fast ....... Would be worthwhile knowing what material we’re dealing with here to avoid damage
I said until it "starts" to bite! I'm not suggesting go to town at high speed without the clutch set (ok, maybe I should have mentioned that bit, I guess I just assumed that everyone knows how to use a combi)
Without being rude to the OP, this is a rather basic question and the OP has been honest with their user name ! Just didn’t want any damage to occur, even if ali or stainless steel - over tightening could deform the splashback around the screw I work with ‘novices’ on a regular basis and have found that you can’t rely on common sense or a general understanding on a topic that they lack experience in Not having a dig at you Bianco, just best to cover our backs Maybe the OP can furnish us with some further details
you are probably not going to be able to remove the old plug as the spash-back drilling will be too small, and ditto you wont get a new plug in. Try shaving down a piece of wood (or 2) about the length of the screw, and poke them in, then replace the screw (I would suggest using a hand screwdriver to get more "feel"). With luck it it will expand the plug to regain its grip. It usually works unless the lose plug has made too big a hole in the plaster.... *** alternatively split a new plug down its length and poke as many slivers in as you can
Sounds a bit high. I hire from https://www.erminplant.co.uk/for-hire/drilling-breaking/drilling/ Anyway. Hope it goes OK..
Sorry, should have provided further details (Photographs as attached). I installed the splash back, 3 of the fixings are tight but the top right hand corner has recently come away from the wall because the hole has become too big for the plug. I do not want to take it all down as it looks like the wall may be crumbly so do not want to disturb the other three fixings as these are good. There is not enough space for me to get the old plug out so is there a way i can fix the plug and the splash back to the wall again by taking the old screw out, keeping the original plug in place and using another type of fixing. The material is not glass, but hard plastic so would crack or shatter.
Why are you reluctant to take out the other screws so you can address the loose rawplug? That would be the best method. I would remove everything completely and make good. Regards addressing the loose rawplug, you can wedge half of a cut down rawplug along with a full one so they sit in tightly together, or you could use a larger rawplug then tap your brown one inside of the larger one.
First question would be............ what is the wall type it is fixed to???? Looks like plasterboard from the close up picture............ very tidy hole (says the nurse.....) Is it dot n dab by any chance or is the plug into the breeze block as it was???
You are making a meal of this, either stick another plug or two in the hole or run a bead of clear silicone down the back of the splashback and strut in position for a couple of hours to let it go off secure.
it may be the wall is not level and its needs packing and retightening the plastic may be saying where it needs to be
But it's not a curtain pole Wayners..... Pay attention. I actually carry some of those as a last resort repair but I've never had to use them. A mixture of the other suggestions has kept me out of trouble so far.
