Loud tap
Discussion in 'Plumbers' Talk' started by yorkshireboy, Mar 23, 2007.
  1. yorkshireboy
    yorkshireboy Member
    I have a problem with a bath mixer tap.
    When the cold is turned on there is a loud vibrating hammering sound from the tap.The hot is fine and the cold in the basin is fine.
    I have checked the washer and it seems fine.
    Has anyone come across this problem before ?
  2. ponty 01
    ponty 01 New Member
    the washer might look ok, but i bet if you replace it the tap will be fine, get this alot with bristan mixer taps,replace washers and they work fine
