I have a combi boiler with pretty poor mains pressure (we're at the top of a hill). Currently have a mixer shower in the ensuite that works fine, until someone turns on a tap! I'd like to add another shower into the main bathroom. I was wondering if there is a way of getting round the low pressure issue without replacing the boiler. There will definitely be times when both showers are needed at the same time.
I was thinking about adding a cold water tank in the loft and running a gravity fed electric shower in the bathroom, would this work? Could I set the ball cock to only fill when the tank is half empty to try and avoid it drawing water when the shower is being used (as this could effect the pressure on the other mixer shower).
Let me know if this is a bad idea, or if you think it could work!
