Low voltage halogen lights 3 x 12v / 20w
Discussion in 'Electricians' Talk' started by kat'llsortit, Oct 30, 2003.
  1. kat'llsortit
    kat'llsortit New Member
    As these are not something I've installed before I would appreciate some advise. I'd like to install 5-6 lights, and have found the 3 lamp kits in the catalogue, it says beside it...spare lamps quote ...., my question is, is the max amount of lamps on one tranformer 3, or can more be added, or could...should I buy 2 kits and if so do I connect both to the mains. Obviously thinking of safety here so if there is any additional things I should do/know, plz let me know
  2. supersparky
    supersparky New Member
    the kits tend to have a maximum of 20w fittings, if you want more power use one transformer for each light, dont use kits
  3. jj
    jj New Member
  4. kat'llsortit
    ty supersparky, for your advise, wow theres alot more to these lights than I first thought, thats probably why up until now I have been unable to get any blurb on them, but ty much appreciated
    Kat.
  5. kat'llsortit
    ty for your advise,links the kit I was referring to has dimmable transformer screwwfix vol 72 page 152, I noticed on one of the links you so kindly gave me, talk of protection boxes for the lamps, where do I get these? The reason for choosing halogens was because I intend to put a canapy over the bed, but am curious how hot they get to determine height/ distance of canapy away from the lights, appreciate any time you could give this, and thanks again for your help so far
    Kat.
  6. supersparky
    your help so far
    Kat.
    i would say 18inches minimum of 12 for the canopy
    and if you talking about firesheilds, you are unlikly to need one, you only have to use one where the ceiling has a fire rating, eg. it must withstand fire for a set period of time.
    BR
  7. jj
    jj New Member
  8. supersparky
    all apart form the clear, those are pretty ugly lookin bulbs
  9. jj
    jj New Member
  10. supersparky
    why have you posted the same thing twice?
  11. Nigel
    Nigel New Member
    Another option is to fit a timber canopy and install LV lighting in it.
  12. jj
    jj New Member
    RE: "why have you posted the same thing twice?"
    I didn't, look closer.....
  13. jj
    jj New Member
    Re: "all apart form the clear, those are pretty ugly lookin bulbs"
    Fortunately they don't actually come like that, as the design has changed. They actually have a bezel that the l.e.d's poke through and an overall lens to enclose it all.
  14. kat'llsortit
    ty all again, ty also to Nigel for his suggestion of a wooden frame, however I feel it would be a little to bulky and masculine, I want to produce a light airy feel, with voile preferably. Anyway on another note no-one has answered my question of it is possible to rig up 2 kits mentioned above to the mains, as money is none existant getting alot for a little is unfortunately the only option, wardrobe, drawers etc to buy you know how it is, lol, so would it be ok? Can't see why it shouldn't be but it terms of safety I prefer a professional opinion, so get ya grey cells working lads, and let me know, ty again
    Kat
  15. supersparky
    No you cant uprate the bulbs in the kit, or add any, this is why most sparks use one transformer to a bulb system, so dont add or modyfy the kits in anyway or go fot the 1:1 option
    BR
  16. kat'llsortit
    I dont understand what you mean supersparky, if I was to run two separate lights you would put 2 sets of wires going into the mains. I'm not suggesting running 1 kit onto another, surely each kit of 3 bulbs, can be put into the main ring curciut, it would mean 2 blue/brown in the outside sockets of the ring curciut, if I were to place 2 kits, can the main ring curciut not supply 6 lights?
  17. supersparky
    no thats not what i ment, the kits can take 3 lights and are designed to take 3 only, i have seen 3 or 4 added to some kits, dont do this, and as for putting it on the socket circuit, you must have a 3 amp fuse fitted
    BR
  18. kat'llsortit
    No supersparky I said ring curcuit for the lights not the sockets curcuits the 15 amp not the 30 amp, I give up I'll put them up as I intending and if it blows it blows
  19. supersparky
    the lights are not a ring type circuit, they are radial. also 15amp for lights! do you mean 6amp or 10amp at most? 15amps is very high for lights
    BR
  20. kat'llsortit
    sorry type o I meant 5amp, even so straight answer plz if I was to connect 2 kits of 3 lamps each to the lighting curcuit (house) in the same outermost connectors in the junction box of the lights would it be safe, the same connections you would use for a standard light bulb connection, only in my case as there are 2 kits 2 sets of brown/blue rather than the one. plz give me a straight answer its holding up the refurbishment
    Kat
