Low water level in toilet after flushing
Discussion in 'Plumbers' Talk' started by DIYDave, Jul 20, 2013.
  1. DIYDave
    DIYDave Guest
    Hi all
    Downstairs loo been there for years with no problems
    Flush is fine and cistern fills back up quickly
    No changes to any plumbing, drains, nothing added or removed
    Just started that when you flush, toilet bowl starts to refill then you can hear the water being sucked out of the bowl, leaving just an inch or so at the bottom
    Would appreciate some advice on this one please
    Many thanks to you all and enjoy the weekend
  2. Sean_ork
    Sean_ork Screwfix Select
    there's a blockage somewhere in your drain
    do you have a manhole on your property ?
  3. DIYDave
    DIYDave Guest
    HI Sean and thanks for reply. Manhole in back garden and runs to next door property. Everything drains into this manhole, gutters, 3 toilets, bath, sink and washbasins . Will lift cover and take a look. Although 3 toilets empty into this manhole it's only ground floor loo affected
    thanks again
  4. Sean_ork
    get a plunger on it
  5. tom.plum
    tom.plum Screwfix Select
    I'd say the vent or dergo is blocked, thats what stops the water seal being sucked out, Do you know if you have a dergo?
  6. DIYDave
    DIYDave Guest
    HI Tom. Pretty sure no dergo valve is fitted , downstairs toilet was added about 7 years ago along with extra bedroom and en-suite. Downstairs loo, 1st floor ensuit (wash basin, toilet, shower ) all run into new manhole which then runs into existing manhole . As I say, since this building work there has been no further changes to any plumbing. Think I will lift both manhole covers tomorrow and take a look. Always a nice job before ur lunch . Thanks for the advice so far
  7. DIYDave
    DIYDave Guest
    Hi all and thanks for advice - sorry not had time to update
    Purchased a set of drain rods and after feeding 9 metres into the manhole I hit the blockage which was then easily shifted, drains then emptied immediately
    Thanks again and for under £20 for drain rods, a good investment I reckon
