Zeus tables are the best source for this type of info http://www.chronos.ltd.uk/acatalog/Chronos_Catalogue_Data_Charts171.html Jason
I've still got my copy of Zeus from apprenticeship days around 40 years ago (that dates me!). Think they were less than 10p (well less than 2 shillings) in those days but looks like now around £6.50, guess that's inflation for you! Over the years, it has though proved to be a very useful book.
two questions please on zeus do they have sharpening angles in them and are they available from other than mail order
If you mean what angle to grind a tool for screw cutting in the lathe then the answer is yes, 60 degrees for metric threads. If you mean angles for turning tools to suit different materials then no but let me know what you want to turn & I will let you know. Most industry now uses tools with replacable carbide tips now but if you are not cutting at their rates with heavy coolant then a brazed tip carbide tool will give a better finish in most cases. Im sure if you look in yellow pages for local engineering supplies one of them will keep it, or you should be able to order one through a local book shop, of if you live near the site I posted a link to you could pop in there. Jason
Tembo, i picked my copy of Zeus up in waterstones bookshop. They had it in stock. if your local one hasnt, im sure theyd be glad to get it in for you. £5.00
Thanks Do you have an ISBN for it please. I had checked the B'ham Waterstones but couldn't find it. I knew approx what it should look like but couldn't for the life of me remember what it was called. Richard
This may be of help to you - Zeus precision data charts and reference tables for drawing office, toolroom & workshop ISBN: B0000CLZUO, I have seen these on an auction site begining with E for £4.50 if you are unable to get to a bookshop.
If thats the ISBN off Amazon then it was a 1963 edition so ISBN may be different if there is one at all. Jason
http://bhinone.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=231801&N=401 Given that I started the search for this The above is the link from the Buck & Hickman engineering web site @ £3.50 Richard
Looking at my newest Zeus book, metric revision 1972, I found the ISO metric threads and surprise surprise a 6mm thread is 6mm. Whatever next?
