maglock
Discussion in 'Electricians' Talk' started by scoobydont, May 1, 2007.
  1. scoobydont
    scoobydont New Member
    does anyone know if an a/c maglock is available to work with a keypad and phone entry system.
  2. Clark Kent
    Clark Kent New Member
  3. Lokkars Daisy
    Lokkars Daisy New Member
  4. RMH
    RMH New Member
    Any maglock will work with an entry system so long as you use a decent power supply unit as they can require a fair bit of current to initially energise. You will probably require a relay in between the phone system and lock, just make sure that its surpressed.
    Dont forget that unless you use a PSU with back up battery the system will fail open.
