hi. first time in here just wondering has anybody ever fitted for magnet and r they n e gud. is it flat pack or rigid and do the draw fronts and doors come on the units ( if rigid) any advice would be help ful cheers folks
mainly built up units, depends on spec, drawer and door fronts fitted on built up units, good luck on getting paid if the fit isnt "complete" then you dont get paid, and guess what, some bits are missing from deliveries so you have to re-visit to finish,,, then you get paid. good luck mate, its bread and water for you if you can carry yourself for a little while
cheers m8. how do u go about gettin ur own work u supply and fit or sub 4 differnt companys? just wanna c wot other people do
Magnet kitchens are generally factory assembled units, except for tall housings and wall and floor corner units. The reason for this is to make it easier to get the more awkward units into buildings. They are 15mm thick carcases The drawer boxes are fitted to the units but door and drawer frontals are not, they are separately packaged. Generally pretty good at getting everything in one drop, but take care and throughly check the delivery against the delivery note. Its worth making friemds with the staff in the local branch as they can really help with shortages, breakage and cock ups.
I really hope you don't decide to type up your quotes and invoices in SMS shorthand. If the customer thinks you're unable to write properly they'll doubt if you're able to use a tape measure.......
