Hi all, wonder if some has done quartz before, i have fit loads of kitchens ,but never used quartz, the kitchen has come with cutting discs and jointing compound , polishing pads etc etc ,,HELP''''' Do i use a grinder ? is it a butt joint that's used ? is the worktop quartz all the way through ? Any pointers would be greatly received
well i sorted it, its as easy as laminate tops,used the cutting disc provided ,,cuts easy,, plastic in the centre
