making a ledged pine door
Discussion in 'Carpenters' Talk' started by woodburner, Mar 10, 2008.
  1. woodburner
    woodburner New Member
    Hello,
    Apart from a reclamation yard does anyone have any ideas where would one buy tongue and groove, bead and butt, planks around 150 mm wide and 20 mm thick to make a ledged door?
    Cheers,
    wb
  2. parana
    parana New Member
  3. jasonb
    jasonb New Member
    For pine I think you will have to buy T&G and then add the bead with either a combination plane or router with beading bit. I know you can buy beaded T&G in oak, but not pine.
    Jason
  4. joinerjohn
    joinerjohn New Member
    As Jason says, buy t&g and route the bead yourself. Looks nicer with the bead.
  5. lamello
    lamello New Member
    Whereabouts are you?
  6. woodburner
    Many thanks for all the replies. Funnily enough I had thought of using t&g floor boards as I have some but thought the idea daft. I have no routing experience but will give it a go.
    wb (in Oxfordshire)
