Makita impact driver losing power
Discussion in 'Tool Talk' started by rsk, Sep 23, 2021.
  1. rsk
    rsk New Member
    My DTD146 Makita impact driver is losing power. It's not a brushes or contacts issue because it runs smoothly, it's just a bit sluggish on starting and lacks a bit of power . Anyone know what else is there to go wrong on them?
  2. Wayners
    Wayners Screwfix Select
    Grease the hammer as I do mine every few years seems to help keep it run nicely. Easy enough to take apart.
    Just replaced motor in mine as was getting sluggish then started to smoke a lot. Bought off ebay and took about 15mins to swap as easy job
  3. Kas228
    Kas228 Screwfix Select
    Battery not what it was?
  4. rsk
    rsk New Member
    Cheers i might look at replacing motor
  5. rsk
    rsk New Member
    Not a battery issue: i tried swapping batteries with another driver of the same model
