Manifold issue
Discussion in 'Getting Started FAQ' started by LP1, Sep 9, 2019.
  1. LP1
    LP1 New Member
    hi all,
    I am after some advice I have just had my header tank repositioned and pipe changed from 18mm to 22mm due to the header tank been scorching hot and water coming up through the vent pipe, upon getting this fixed the gas engineer has find another fault the radiator pipes have corroded and one has actually come away from the manifold, The manifold that has been in years is now obsolete and cannot buy anymore to top it off the pipes vary with some at 8mm and others at 10mm is there a reason for this?, is it worth getting new manifold ? Please see photos and any help with this would be massively appreciated
