MASK RESPIRATOR
Discussion in 'Builders' Talk' started by enc, Oct 10, 2018.
  1. enc
    enc Active Member
    Iron_Mike likes this.
  2. KIAB
    KIAB Well-Known Member
  3. Richard_
    Richard_ Active Member
    I found the GVS Elipse to be the most comfortable, especially if you're going to be wearing for hours at a time. The ones with a cannister that clips on the side tend to feel to bulky especially when you turn your head.
  4. teabreak
    teabreak Well-Known Member
    I use the force 8 good mask, I agree the hazards filters protect you from are confusing, just give Screwfix a ring the operator will find out for you. I have found them very helpful.
  5. enc
    enc Active Member
    thanks all. i bought the force 8. i understand it should be ok for my needs .
    cheers
  6. Iron_Mike
    Iron_Mike Active Member
  7. KIAB
    Good thing with 6000,it's available in three sizes & you can use 2000, 5000 and 6000 Series Filters.
    Using 3M 6035 Particulate P3R Filter & the cheaper 5935 P3R filters, plus a few others.
    https://www.arco.co.uk/products/111500
  8. Iron_Mike
    Cheers KIAB
  9. enc
    enc Active Member
    Hmm!! Having trouble aligning the arrows on the mask with the arrows on the filter so that the filters are straight.
    Called jsp help line they say it takes a real hard twist of the filter :-/ hope it's covered for accidental breakages cause these things are bloody tight :-s
  10. enc
    enc Active Member
  11. teabreak
    Yes they are hard to turn, just ensure they are on correctly and go for it, I guess you could lightly moisten the seal with a wet finger.
  12. enc
    enc Active Member
    I spoke with the jsp helpline who are aware of the issue. Bottom line is they are a tight fit. I think unreasonably tight tbh. Managed to get the filter in place using a silly amount of force ... no wonder they are called force 8 ... I'd say a 10 personally. To be fair to jsp their help line is very good .. a refreshing change to the international help line one encounters with Virgin media.
    teabreak and KIAB like this.
  13. KIAB
    My 3M 6000 mask,it's just a quarter turn,& hardly any pressure needed to attach filters.
  14. teabreak
    See us Force 8 users are well 'ard!;):p:p:p
    WillyEckerslike likes this.
