Masking Tape on UPVC
Discussion in 'Painters' Talk' started by Pikerray, Jul 4, 2009.
  1. Pikerray
    Pikerray Member
    I am having trouble getting masking tape of my UPVC framed windows, some of the tape comes off and some remains which is a pig to get rid of.
    The windows are new and I do not want to risk scratching or damaging them, so whats the best way to clean off all the remnants ?
  2. Astramax
    Astramax Super Member
    The best way is: Buy the correct masking tape for the job, as there are many different types available.
    Not leave in stuck on for longer than stated by the manufacturer.
    For cleaning off the adhesive try WD40.
  3. potty painter
    potty painter New Member
    Good advice, and WD40 will shift it. With regard to the masking tape always remove when the paint is becoming touch dry, pulling gently outward away from the painted surface.
    Potty.
  4. Pikerray
    Pikerray Member
    Thanks lads,
    Is there a No! No! when it comes to UPVC what about white spirit ?
    I will take up your WD40 suggestion though.
