masonary paint
Discussion in 'Painters' Talk' started by kidspud, Dec 5, 2003.
  1. kidspud
    kidspud Member
    Should be a nice simple question.
    I have fresh render (only 2 weeks old) which I will be looking to paint as soon as the weather permits.
    What paint/prep would people recommend.
  2. unphased
    unphased Screwfix Select
    masonry paint would be fine
  3. Ben
    Ben New Member
    Before I paint new render, I always coat the render with stablilising solution first. I find it helps bond the paint to the render, but I don't know if this is standard practice for painters.
  4. out of africa
    out of africa New Member
    Freshly rendered surface is quite alkaline. Bens advice to use stabilising solution is quite correct. It also saves on paint (lower absorbtion).
    I normally use waterbased masonry paint but instead of using stabilising solution I dilute the first coat of paint by 10%, i.e. 500ml water to 5 liter of paint. I apply slowly (to prevent dripping and splashing) using a cheap roller. If it is good quality masonry paint, when you apply the second coat it should completely cover the plaster.
  5. Allsorts
    Allsorts Well-Known Member
    Would it make sense to let the masonry weather for a few weeks? Get some good ol' rain to wash away the excess alkaline?
  6. DIYDave.
    DIYDave. Well-Known Member
    Ha ha ha ha and bluddy ha ha ...... etc .......
    ‘Let the masonry weather for a few weeks’ ...........
    Have you seen the date of the post :D
    It’s been dragged up by another idiot t osser low life :confused:
    Good point though DA :)
    Allsorts likes this.
  7. Allsorts
    Fair do's - it must be ready for a coat after 15 years... :oops:
    (Pfffft - I could have deleted my post and made yours look silly... :p )
  8. DIYDave.
    All in jest liquorice :)
    Unlike these blinking trolls, getting more and more frequent and idiotic
    SF need to up their game to prevent / eradicate these idiots ASAP
    WillyEckerslike and KIAB like this.
  9. KIAB
    KIAB Well-Known Member
    We wish!
