Masonry Paint / Problem
Discussion in 'Painters' Talk' started by ChrisChris, Mar 20, 2022.
  1. ChrisChris
    ChrisChris New Member
    Hi just wondering if anyone could advise me on the following problem....
    Cement sill running across the house was damaged and was patched up. It has had numerous coats of Sandtex masonry paint over it but I’m still getting show through at various points. It gets painted the marks disappear and then reappear
    Thanks
  2. Astramax
    Astramax Super Member
    Looks like Efflorescence, try neutralizing the crystals area with White Vinegar.
  3. ChrisChris
    Thanks Astramax I’ll give it a go
  4. Astramax
    @ChrisChris, commercial Efflorescence treatments are also available.
  5. ChrisChris
  6. Astramax
    Efflor-treat has good reviews, try the white vinegar though, start with a 50/50 with water ratio, stronger if required, brush on and leave for 15 mins wash off and repeat if needed.
