I have a small air compressor in my garage supplying air to my treatment plant around 10m away. I would like to incorporate an air flow gauge into the rigid air supply pipe, either connected directly inline ( think pipe is about 25mm) or external to the pipe with some kind of sensor within the air flow. Having a gauge will indicate the pump performance and highlight any blockage at the outlet within the treatment chamber... looked online several times to try and find something suitable at a reasonable cost but just can't find anything other than really expensive Industrial kit. Wondered if anyone on the forum had any ideas or suggestions as to something that could be used. I was hoping there would be a gauge similar to an air pressure gauge with flow sensor that I could fit by drilling and tapping into the rigid pipe. Thanks.
