Metal Routers
Discussion in 'Engineers' Talk' started by blonker, Nov 21, 2003.
  1. blonker
    blonker New Member
    I borrowed a old stencil. I traced it on metal sheet intending to cut out the letters then use it as a tracing medium for a wood router many times. I am lost as to how cut out the letters as i will not be able to boorrow the stencil again. Is it a case of chiseling by hand, metal router or laser cutter ?
  2. Markybob
    Markybob New Member
    chisel or cnc router, about 15k. your call
  3. Maintenance Man
    Maintenance Man New Member
    Cant you use a jigsaw with a metal cutting blade in it?
  4. matty
    matty New Member
    YOU could hire a plasma cutter for a day or two for around about £30-£40 or you could use a jigsaw with a really fine metal blade depending on the thickness on the sheet or plate of metal
    mat
