meter tails
Discussion in 'Electricians' Talk' started by crisp, Jan 30, 2004.
  1. crisp
    crisp Member
    can any one tell me if 25mm meter tails will fit in a standard domestic meter or should i use 16mm.i was thinking of using 25mm as the incoming fuse is rated at 100amps and i been told 25mm will carry 125amps.i also been told 16mm will only carry about 80 amp and therefore would melt before fuse did. so i need to know if the 25mm will fit in meter.
  2. supersparky
    supersparky New Member
    of course they will, otherwise anyone rewireing would be pretty buggered!
  3. crisp
    crisp Member
    thanks ss for that i was just worried in case the 25mm i bought wouldnt fit in the terminals of the meter thanks for the reasurrance
  4. supersparky
    n/p mate
  5. The Trician
    The Trician New Member
    It's up to your supply authority to ensure that you have the correct sized tails(25mm) and that their meter will accomadate them. No worries:)
