Min max height of fan isolator switch
Discussion in 'Electricians' Talk' started by Mattttt, Sep 22, 2022.
  1. Mattttt
    Mattttt New Member
    Is there a minimum or maximum height in a new build (extension) for a bathroom extractor fan isolator switch ?
  2. chesterw
    chesterw Well-Known Member
    No, but the sensible place is as close as possible to the fan, the standard way is a suitable pull cord switch
  3. ElecCEng
    ElecCEng Screwfix Select
    OSG any building regs guide group all switches in the same section. Have a look there. We normally fit them central above the door as a) highly unlikely that someone can reach from inside the bathroom, b) shorter cable runs, c) discourages accidental or deliberate turning off of the fan. Although you can buy lockable ones to prevent tenants disabling the fan then complaining of ‘damp issues’.
    Pull cords are fine but look a bit dated in a modern bathroom.
  4. Mattttt
    Mattttt New Member
    Cheers guys
  5. WillyEckerslike
    I've been working in a property today where the ensuite fan isolator (a conventional rocker switch) was located in the ceiling of that room. Never seen that before.
  6. Bob Rathbone
    Bob Rathbone Screwfix Select
    Where can I get a 3 pole pull cord switch if the fan has a timer.
  7. Ind spark
    Ind spark Screwfix Select
    CEF.
    Or this one at city plumbing.
  8. rogerk101
    rogerk101 Screwfix Select
    I found plenty of them on eBay.
    My spark wasn't happy with my ceiling mounted rocker fan isolator switches in my rental, and wanted them changed to pull cord switches. I found plenty that didn't even need the back box altered in any way.
  9. chesterw
    Anywhere, made specifically for isolating fans for donkeys years
