Hi, I am trying to remove the outlet elbow so that I can have wet wall fitted. I understand it should twist to separate the two parts as they are on lugs, but I am struggling to do this. There is a minimal amount of movement, so not seized, but they will not rotate to line the lugs up. Any suggestions? Thanks, Tim
Hi Kiaora, I eventually had to get a plumber. He did it in about 30 secs! There was a small bit in the outer ring that was locking it and needed to be pushed with a small screwdriver blade through a gap to allow the outer ring to rotate. Thanks for your reply.
