Mira Mixer shower problems since combi boiler installed
Discussion in 'Getting Started FAQ' started by Shona Gordon, Oct 26, 2018.
  1. Shona Gordon
    Shona Gordon New Member
    We have a Mira mixer shower which worked with a condensing boiler and also had a pump fitted due to low water pressure. We had new Worcester Bosch 30i combi boiler fitted last week. Since then the shower comes on at normal pressure for 90 seconds then pressure drastically reduces - if we turn up heat pressure returns but after 90 seconds drops to practically nothing again. Installer saying must be shower fault but it was working fine before new boiler installed. Any ideas please?
  2. Mike83
    Mike83 Screwfix Select
    What model of shower?
    Was the previous boiler also a combi ?
  3. Shona Gordon
    It is a Mira Excel and no previous boiler wasn’t a combi
  4. Mike83
    So the shower was previously fed from a hot water cylinder.
    Was the cold to the shower also converted to mains pressure when the combi was installed?
  5. Shona Gordon
    Yes previously fed from hot water cylinder and cold water tank in loft. Presume it was set up to have cold from mains.
  6. Mike83
    If the hot and cold pipes are out of balance it would cause issues with the shower.
    Need to try confirm if the shower cold is from the mains.
    Do the cold taps in the bathroom have more pressure than before the boiler change?
  7. Shona Gordon
    Yes the cold taps have more pressure than before. I’ve just turned shower down to coldest setting and there’s no water coming out so I think you’ve solved it - I don’t think they connected the cold to the shower to the mains!
  8. Mike83
    They may have left something isolated on the feed to the shower by mistake
  9. Shona Gordon
    Thanks for your help. I’ll get back on to the company that fitted the boiler on Monday.
