Mitre joint
Discussion in 'Carpenters' Talk' started by Hover Tim, Jan 11, 2007.
  1. Hover Tim
    Hover Tim New Member
    Hello chippies
    I am doing a job for someone and i need to joint two sheets of MDF together i was thinking of a maitre with a grove cut down and a grove on the other board and a length of timber say 10mm wide to hold the miter in place as i don't want to screw it is there another way to join boards
  2. M.I.G.
    M.I.G. New Member
    yeah you can biscuit joint it but you've gotta have the tool to do it with.
  3. makita49
    makita49 New Member
    Whats the job for?
  4. dirtydeeds
    dirtydeeds New Member
    mitre is the wrong joint for boards. what is the job for
    playing secret squirrel wont get you the answer you want
  5. joesoap
    joesoap New Member
    H'mmm he's still hovering eh???
  6. Hover Tim
    i am not hovering at the moment hopefully soon though!!
    the job is for a heater cover
  7. joesoap
    joesoap New Member
    Ok Tim no sweat, no offence meant Cheers !
  8. dirtydeeds
    the quickest most effective method is a biscuit jointer
  9. joesoap
    joesoap New Member
    Tim
    The question is still unclear , if your struggling come again , help is here if required. Cheers !
  10. Hover Tim
    Ok
    i am making a heater cover and i am not sure which joint to use at the corners as i dont want to screw it
  11. cockneycowboy
    cockneycowboy New Member
    Hi Blokes. I ain't a chippie,so shoot me down in flames if you want, but as I understand the problem, Tim wants to join 2 MDF boards at 90 degrees & is asking about rebating each board & then beefing up the joint with 10mm square strip.....sounds OK to me...
    Regards, Malkie
  12. joesoap
    joesoap New Member
    Ok Tim
    Really it's down to what your using and what tools you have and the designs are wide and varied. I'm sure some one here can pass you a patented plan and you could take it from there. To join say 6 or 8 mm pegboard mdf would not suffice . If you can router you could house the front in to a frame and use sold ends and top with a shaped plinth. To butt two 10mm boards without fixings is not on. Go look at a ready made job and start again. Good luck . I'm sure a plan will be with you from here soon. Cheers !
  13. joesoap
    joesoap New Member
    that should read Solid ends
  14. cockneycowboy
    ....Tim, I think that you would be better off with a 20 or 25 mm strip if you want to glue &/or pin it..Malkie...
  15. dirtydeeds
    butt joints in MDF, biscuits
    corner joints in MDF, biscuits
    tee joints in MDF, biscuits
    a cant make it any plainer, USE BISCUITS and stop listening to the drivelling numbskulls
  16. cockneycowboy
    Hi DD. Maybe Tim hasn't got a biscuit jointer...Hardly worth buying for one job. If he rebates the edges, he can use a router or even a circular saw at a push. I'm sure that your's is the correct way, but sometimes us amatuers have to compromise (bodge ?)....
  17. yorkshireboy
    yorkshireboy Member
    Why not just screw it together and fill the screw holes.What is all this rubbish about biscuits.The biscuits wont hold the joint together until the glue is set
    If you wanted to be fussy the corners should be mitred glued and pinned
  18. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Personally, I would butt it, glue it, and fix it inside with stretcher plates(90°)for the corners, IF the design allowed for the brackets to be hidden.
    Mr. HandyAndy - really
  19. dirtydeeds
    dont some of you ever listen
    biscuits are for lining up joints
    never mitre structural joints (in any medium, timber, MDF, MFC) they have no strength and you cant reliably cut a long mitre
    dont pin MDF joints it splits the MDF
    screws in MDF always predrill use 3.5mm dia screws (not 4.0)
    gluing joints is a given, didnt think it had to be said
  20. joesoap
    joesoap New Member
    Now Deedsy
    There's more than one way to skin a cat so put the cork on the bottle and relax. It is Sunday you know. Cheers !
