Can anyone help please I am trying to mitre worktops and whatever side of the jig I use I am getting a radius cut on the female and a non radius on the male I have tried keeping the guide bush tight to both side of the jig and still I get the same outcome I cut the female face side up and the male face side down Am I missing something obvious please it’s driving me crazy
Sounds like you are not putting the pegs in the jig for the male cut. What jig are you actually using ?
When cutting the male have you got both pegs in the 2 holes that will be just to the right of the tip of the run in side of the male cut ?
Sorry for delay been out replacing worktops that I messed up Yes mate all the pegs a present and in the correct places
I’ve cut them upside down ,back to front ,inside out . I give up I replaced the work tops and walked away full off apologies and embarrassment Can’t understand I have done this a dozen or so times before Thanks for your help
I can't understand how you could have done it wrong ? Have you got any pics of the jig in place ? or the jig itself ?
Should have cut the female and then laid the piece you wanted the male on on top and marked a line on underside then you could of set up jig and router checking the router would follow the line this would of eliminated user or jig error
