My girlfriends shower head packed in, No problem easy replace, but now It won't actually come out of the shower head And there isn't a diverter to be found to switch tap and shower. Can some one help coz i think I'm being a bit stupid here?
the shower head " packed in" ? Do you mean no water was coming out of it ? If so ,the diverter may be the issue. As said above ,it pulls up / down.
It doesn't want to go up or down, it just spins. The shower head was leaking out of the seems. It was getting water pressure before I detached the hose
When turning tap on ,does water come out the spout into the bath ? If so the diverter should pull up ,to alter flow to shower head. Try turning whilst pulling it up. Very unlikely that it has seized up ,if all you did was unscrew the hose .
