F
Finetunemoon
Guest
hi all, I’ve been having a go at some DIY again today to try and fix my kitchen mixer tap out
The issue is that the taps when closed don’t shut off straight away but there is a trickle and a drip,
When you shake the mixer spout it does stop the dripping after the tap Has been shut off
I’ve had the spout off replace the O rings on it and had the tap handles off to have a look at the valves I managed to get the cold valve off although it was very tight and took a while to shift, looked fine (although it was a valve for a hot tap, red circle on bottom)
I could not shift the hot tap valve it was stuck solid tried wd40 but no luck
So clean up what I could and put it all back together, it still has the issue
But when the spout is off there doesn’t seem to be any leakage from the tap so surely the valves are doing there job?
Also would having the hot and cold valves round the wrong Way matter?
I can post pics tomorrow if needed
Thanks
FTM
Thanks
FTM
