Most cost effective way to paint a full 2 Bedroom house.
Discussion in 'Painters' Talk' started by bond007, May 13, 2019.
  1. bond007
    bond007 Active Member
    Guys
    Taken over a property which needs some TLC. Going to give it clean and full paint.
    Wanting to know which is most cost effective way to paint the whole house walls. May do the ceilings too.
    Going for standard white.
    Dont want to be doing many coats so ideally if can get away with it, then a ONE coat base paint.
    What kind of tackle is good and easy to use, especially for ceilings. Not looking for anything to a professional level, just basic DIY but clean.
    Could the same paint be used on skirting board and door frames too?
    Carpets going to be ripped out and replaced so not to bothered about the mess.
  2. sospan
    sospan Screwfix Select
    Paul Pownall and Dam0n like this.
  3. Astramax
    Astramax Screwfix Select
    Sounds like a 'LET' property..............white ceilings and woodwork with Magnolia walls, cheap as chips! ;)
  4. KIAB
    KIAB Super Member
    Hire a medium airless paint sprayer, & use with 20 ltr tubs of Magnolia/ white emulsion, can quickly spray a room.
    Once all rooms are prepared & clean, & with the 50' hose on most sprayers, it's eay to set up sprayer in central location & spray one room after another.
  5. bond007
    This wil need to be removed and skimmed again?
    Any other way round it?
  6. bond007
    I got a similar one already which i used to paint outside fence.
    Used to much paint with that and the capacity is only small so for ever filling it after every 5 min of use.
  7. KIAB
    KIAB Super Member
    As it's already lifting off,a wall paper steamer might get it off with little damage, then just skim & repair any areas where needed doing, then give wall a coat of Everbuild 406 stablishing solution,will give a good surface then for painting.
  8. bond007
    So only that section will need skimming? not the entire wall then?
    Any youtube videos how to learn skimming...lol
  9. bond007
    Currently got magnolia on the wall, will one coat of white cover it or am i best sticking with magnolia?
    Any pain i can use same on the walls and woodwork?
  10. robertpstubbs
    robertpstubbs Screwfix Select
    I think there is a Mr Bean program about how to do it.
  11. KIAB
    KIAB Super Member
    Most likely,without being there, it's difficult being 100%,but based on past experiences, you might be lucky, is that a outside wall.
    I stick with magnolia,you will then most likely get away with just one coat, but again, it depends on the condition of the walls.
  12. KIAB
    KIAB Super Member
    Astramax might pick up a few useful tips...:D
    Muzungu likes this.
  13. bond007
    Yes its an outside wall...joining onto the next terrace house.
  14. KIAB
    KIAB Super Member
    Party wall,rules out damp,so just poor preparation I expect.
  15. bond007
    Any paints you recommend and the correct roller brush to use with?
  16. CGN
    CGN Screwfix Select
    Leyland trade super latex. Comes in 15l tubs, so get one white and two magnolia at first.
    Use a decent primer/undercoat on woodwork then topcoat with white gloss.
  17. bond007
    So will use the magnolia on the walls, white on the ceiling. Im gonna try and see if i can get away with doing white on all. On magnolia, will it need extra coats of white to cover?
    Which primer/undercoat for woodwork
  18. CGN
    CGN Screwfix Select
    If walls are already magnolia, then stick with magnolia. Dulux trade oil based undercoat and gloss for wood work.
    bond007 likes this.
  19. bond007
    What about for the ceilings?...that's currently white...That will need to be painted first right?
  20. gac1967
    gac1967 Member
    Paint your Ceilings first, then walls, then undercoat and gloss woodwork.
