Most Reliable Bathroom Fan
Discussion in 'Electricians' Talk' started by Studentrooms, Nov 10, 2019.
  1. Studentrooms
    Studentrooms Member
    Hi .
    Need to replace a ceiling mounted, 100mm bathroom extractor fan. I use the ones with timer so they run on and get rid of the steam , but the Vent Axia don’t seem to last and aren’t cheap ..
    Appreciate suggestions on cheap but reliable 100mm ceiling extractor .
    Thanks
  2. peter palmer
    peter palmer Super Member
    Manrose seem to be ok. The last vent axia fan I fitted definitely wasn't made by vent axia.
  3. dobbie
    dobbie Screwfix Select
    Manrose and Vent Axia are both owned by the same company.
  4. peter palmer
  5. Bazza
    Bazza Screwfix Select
    Hmm Cheap AND reliable. Tricky.
  6. rogerk101
    rogerk101 Screwfix Select
    I've fitted cheap that have lasted a whole lot longer than expensive, but none of them seem to last more than a few years.
    It's a disgrace how much built-in obsolescence there is in extractor fans! I even had one where the plastic fan was pulling itself off the axle! It was a friction/interference fit wit absolutely no notion of a key or a grub screw to hold it in place. That was an expensive fan!
    Philip Hyde likes this.
  7. Philip Hyde
    Philip Hyde Active Member
    Just make sure when you buy one that it's designed for roof mounting. They use different bearings and some are only designed for wall mounting
  8. Studentrooms
    Studentrooms Member
    Ok , thanks.
    Cheap and reliable is a bit of an ask ...
    What if I ask “fit and forget, even if not the cheapest”
    Thanks
  9. greenback78
    greenback78 Active Member
    I have 15 year old Greenwood airvacs running very well in my house and have just added one in my kitchen.
  10. Grange Handyman
    Grange Handyman New Member
    Airflow Icon, not cheap (sorry) but good, quiet, best condensation extraction I have seen, and the inner closer ensures no back draught.
    Mike58 likes this.
  11. Bazza
    I agree, good funky-looking fan. And you can customise them by adding the modules you want.
    https://www.tlc-direct.co.uk/Products/ADICON30.html
    Mike58 likes this.
  12. Tony Goddard
    Tony Goddard Well-Known Member
    Seen these icon ones in quite a few pub toilets, which indicates they must be fairly reliable running long periods.
  13. Mike58
    Mike58 Screwfix Select
    I have Icon fans at home - they look good and work well.
    Friends have had a kitchen rebuilt and at the distant end where teh cooker is a large Icon have been installed followed by at least 5m of flexi duct - it works well to remove cooking smells.
  14. Sparkielev
    Sparkielev Screwfix Select
    Icon fans are nice I agree, but have found the manrose mft 100 a very good inline fan would always look to fit inline fans if possible
  15. Studentrooms
    Studentrooms Member
    I’m
    Going with a greenwood EL100TR ,
    £60 & 5 year warranty...
    See what happens , but in-line sounds like a good plan .
    Thanks
