MOT ballast?
Discussion in 'Builders' Talk' started by teabreak, Jun 20, 2018.
  1. teabreak
    teabreak Screwfix Select
    Just wondering what does mot stand for when describing base
    layer materials?
    Ta!
  2. Heat
    Heat Screwfix Select
    Believe it or not -
    Ministry Of Transport.
    Apparently because they are the government body who decides it
  3. KIAB
    KIAB Super Member
    Simple!:eek:
    teabreak and Heat like this.
  4. teabreak
    Thanks I had racked my brains for possible combinations, never thought of that one!:D:D
    Heat likes this.
  5. Heat
    I also couldn’t think what words the letters MOT stood for in relation to the product.
    Had to search the internet because I needed to know
    KIAB and teabreak like this.
  6. teabreak
    Thanks replied on KAIB's post then my posting went to hell in a hand cart when I tried to edit it!
    Heat likes this.
  7. teabreak
    :D:D
  8. KIAB
    KIAB Super Member
    Don't expect a plumber to know that.[​IMG]:)
    And 1 tonne of MOT Type One is required to cover 10.1 square metres at a depth of 50mm, or 1.98 cubic metres.:D
    Heat and teabreak like this.
  9. DIYDave.
    DIYDave. Screwfix Select
    Isn’t it also as MOT used to be mainly road scalpings from resurfacing road works
    Think scalpings are still used as well as other materials for MOT layer
  10. Heat
    The only MOT I know about is once a year on my car. :D
  11. KIAB
    KIAB Super Member
  12. DIYDave.
    Thanks Kiab but I’m actually fantastic at getting to sleep and have no need for any outside stimuli. On the odd occasion I do (very rarely) then a slug of something tasty and alcoholic hits the spot
    As for bedtime reading, it’s either the SF catelogue or another fine publication, know as chefs p orn, the mighty Nisbets Catelogue :)
    Been through the Kama Sutra 3 times and after putting my back out, never again I vowed :mad:
  13. ramseyman
    ramseyman Screwfix Select
    KIAB think there may be something wrong with your conversion. I’ve always found 1 tonne of type 1 is equivalent to just over half a cubic metre compacted so for an area 10m by 1m at 50mm deep, equals 10x1x.05 you need about 1 tonne as that’s half a cubic metre agreed but don’t get ‘1.98cu ms’ ?? Unless I’m misreading something?
  14. Pollowick
    Pollowick Screwfix Select
    He has forgotten to invert it! 1/1.98 = 0.50505050505
    And his original sum of 10.1 sq m x 50mm deep is 0.505 cu m
  15. KIAB
    KIAB Super Member
    Blame my calculator/or idiot using it.:oops::(
    ramseyman likes this.
  16. Pollowick
    Abacus!
    KIAB likes this.
  17. Isitreally
    Isitreally Super Member
    @ 50mm i allow 9M2 per tonne, not to far out in guessimates. :D:D
  18. Astramax
    Astramax Super Member
    That's no way to describe a fellow poster. :eek:
