Hi there, I've got the usual problem of bathroom mould, but I'm trying to ascertain what my options are. The mould leaked out of shower cubicle and infected an MDF skirting board. I've ripped out the board, removed all the silicone from the shower, and have cleaned out as much of the mould as possible using black mould remover. I'm about to reapply the silicone, but some areas of black mould still remain, and I absolutely cannot clean them. I'm also assuming that the mould has probably travelled underneath the shower tray. What are my options here? If I properly waterproof the shower with new silicone, and give the space plenty of air and drying time, will the mould I haven't cleaned die off and keep the new silicone in tact? Thanks!
If you’ve used a mould cleaner/remover/ which tend to be bleach based - or simply use household bleach to clean, then the mould should be killed off The black marks remaining are likely to be staining from the mould, not actual living/breathing mould (unless you have a super mutated variety in your bathroom ) What surfaces are these marks on though ? If glazed tiles then I’m surprised the marks can’t be removed with bleach and ‘elbow grease’ Shower tray ? Acrylic or stone resin or porcelain ? If acrylic / plastic / stone / these are slightly porous so staining can happen, also if textured, more likely But again, bleach and scrubbing may finally remove marks and a final wash down with soapy water and/or bathroom cleaner If really stained though, but mould has been killed off, new silicone over the top should be fine Just ensure surfaces are clean, dry, and all traces of old silicone removed A silicone eater is good here for removing stubborn remaining bits, followed by a quality silicone, finished with a profile tool - not a finger shoved in your gob to moisten https://www.screwfix.com/p/no-nonsense-sealant-remover-100ml/88987 https://www.screwfix.com/p/dow-785n-sanitary-sealant-white-310ml/800fg This is a good product for keeping the nasty stuff away and general bathroom/shower cleaning - the best I've tried https://www.britishcornershop.co.uk...MI8Nnav7Ks6gIVyu7tCh3FIgR_EAQYASABEgIMnfD_BwE (Price seems to have risen sharply since this covid business though)
Thanks, Dave, appreciate that response, mate. By what you've said, it sounds like the remaining mould is actually just staining, because it's only affecting the grouted areas. That's reassuring to hear. I've since wiped down everything with spirits and reapplied a high quality mould resistant silicone. I went with the Unibond one, I didn't see your link before, but I did get the sealant remover, too, which is bloody good. Did use a profile, tool, too. Way nice finish! Thanks again mate
