Mouse to suck cables through conduits/pipes?
Discussion in 'Screwfix' started by BikerChris, Sep 14, 2018.
  1. Pollowick
    Pollowick Well-Known Member
    You will often seen long lengths of MDPE in skips - builders buy the standard 50m coil, use half and dump the rest!
    I might be inclined to put some form of warning tape on top or wrapped around though - just in case in future someone digs down and finds "water". I know it will only be 5v but the hassle would be a real pain.
    KIAB likes this.
  2. KIAB
    KIAB Well-Known Member
    Good idea about tape, usually green for telephone/fibre.
    https://www.ebay.co.uk/itm/CAUTION-...hash=item25dd01fd0e:m:mmQ34PwOxyoCGqMNr7XTwWg
    And skips have been pretty poor around here lately.:(
  3. MGW
    MGW Well-Known Member
    Never thought of using a mouse, have used a cat to thread new cable through the girder like section of a cherry picker, even filled in a time sheet for cat and sent it to boss.
    I suppose it all depends on what pets you have!
  4. KIAB
    Seen a plumber use a ferret to put draw cord under a supended floor where crawl space was only inches to pull through a new mdpe pipe, & spark use same ferret to get some cable through a area on first floor , save lifting very wide old floor boards.
  5. MGW
    Come back Compo
  6. BikerChris
    BikerChris Member
    Wow, that ain't bad at all. Cheers for that again mate, very much appreciated.
    KIAB likes this.
