at the moment the cu is in the basement next to the main fuse, but thats 10m away from the top of the stairs. if there is a problem it can be difficult to get to. will it be okay to put 25mm tails on and move it to the top of the stairs and do i need to put an isolator by the main fuse.
Concur with Sen..don't forget discrimination OP..or is that all a load of rubbish? Example if the cutout is 100 Amps then the switchfuse would be 80 Amps..is this discriminatory fusing factor still needed?
Although appreciate away from fuse discrimination then 80 (or even below that in some rare cases) could be indicated.
There are always many ways to solve a problem... I would suggest that http://www.screwfix.com/app/sfd/cat/pro.jsp?id=43017&ts=26469 May provide the simple and cheaper answer Evening to all my old friends.... back in a few weeks..lol
JP found one to do the job but to i fit it closer to the DNO or the CU. X good idea i will be fitting that as well never thought of that one,was going to use torch.
Hi St Clair. Here is a picture of an EM light in my intake cupboard (cupboard under the stairs) The switch defeats the supply which turns it on (also handy for testing)..nowt else to say on the matter really, but may help.
I recently moved a cu on a 60a cut out. Used 10m SWA (OP Don't use tails unless they are surface mounted all the way). Put in an isolator but didn't bother with a switch fuse as after working out the Zs it seemed pointless to have a 60a cut out in line with a 60a switch fuse. How is that going to make anything any safer?
Well, you know what, I tried doing some extensive research on this, rang the DNO, surfed like **** but as far as I can tell there doesn't appear to be any actual requirement under law to do this, so I didn't. It just seemed totally pointless.
During my very long employment with LEB & EEB, the only requirement was for a DP isolator without the need for such a silly downgrade of the service fuse. Something has gone wrong somewhere........ Lucia.
It just seemed totally pointless. ------------ I agree Col, it's a bit like exporting tncs earth, difficult to find definitive answers!
Maybe its because instead of 25mm tails people are using 16mm, thus necessitating the use of a switchfuse? This is with respect to a 100 Amp cutout ,and a run over what 3 meters.
JP, I do recall I did the maths and even with the given figures in 7671 guidence I recall the run could be about 50m before you had problems so long as the right sized swa was used.
