Hi I just saw this mower http://www.screwfix.com/p/40cm-3hp-hand-propelled-rotary-lawn-mower-with-briggs-stratton-engine/42691 on the screwfix email, I have always used a hand propelled Mower. Is it worth the extra £20 for a self propelled version http://www.screwfix.com/p/40cm-3hp-self-propelled-rotary-lawn-mower-with-briggs-stratton-engine/57652 Cheers Mal
hi mal, i *think* the only difference is with the self-propelled it gives you the option to control the blade, i.e the engine can be running but the blade not spinning giving you a bit more control over the mower. If it were for me, i would pay the extra as if you stumble across something in the lawn that you didn't know about you can release the lever which would be quicker than trying to move the mower possibly. Your choice thou!
Surely self propelled means the mower will move along without manual pushing? (although I don't actually know for certain). This implies some sort of drive mechanism to the wheel/s. Unless you are unfit/have steep slopes on your lawn/lazy I would have the non self propelled version. After all there's more to go wrong/adjust/set up/ work poorly with the extra mechanism. And mechanisms on a wet, long grass lawn have a habit of clogging/dying very quickly! diymostthings
SElf propelled means it saves you pushing it along as it has normally the real wheels driven. I contract cut grass and would hate to have to use a push along mower for the sake of 20 notes I'd buy it and not look back. Happy grass cutting
i agree with Guss, self propelled for me, ive done a fair bit of gardening work and rely on the self propelled power. i now only cut my own lawn but still use self propelled. i would say this though, if your lawn is all bits and bobs, lots of turns etc without many straight runs then a self propelled could be a hindrance. but for larger lawns sp is a must.
I have always thought that self propelled, means the wheels are driven. for the sake of 20 quid I would go for a driven mower.
sorry for the confusion chaps - just re-read my reply and of course self-propelled mower pulls itself. Sorry! :'(
I went for the self propelled version, and it was worth it much more easy to mow the lawn. Thanks for your help guys Mal
