multi finish/board finish
Discussion in 'Builders' Talk' started by shade695, Nov 6, 2006.
  1. shade695
    shade695 New Member
    ok here's one for a topic is there anything that can be used for a retarder for finish plasters or base coat plasters without causing too much shrinkage or loss of bonding to surfaces.
  2. dj.
    dj. New Member
    **** in it!!
  3. hallbeck
    hallbeck New Member
    NOt sure if this is what you mean, but multi goes off slower than board finish when used on p/board
  4. I hear tell a splash of pva works in the gaugeing water, but have never tried it
  5. nearnwales
    nearnwales Member
    My grandad used to say to me he had a gang of plasterers subbing to him, and they used to put lime in the skim to hold it back, ever tried it thou.
  6. layiton
    layiton New Member
    Lime is ok in skim if skimming browning or the like,but NEVER use it if skimming boards cos it will blow! nite nite.
