Multi Tool Dust Extraction
Discussion in 'Carpenters' Talk' started by Mark8par, Oct 2, 2019.
  1. Mark8par
    Mark8par New Member
    I am trying to find a good solution for dust extraction in my garage. I have a Dewalt DW717XPS saw and various dewalt hand tools.
    I am expecting that I might need a different type of dust extractor for the saw and I may add a table saw at some point but I would also like something capable for my palm sander, circular saw etc.
    Possibly have a budget of about £500 or slightly more if its worth it.
  2. Wayners
    Wayners Screwfix Select
    Shopvac with power take off.40mm sink waste pipe over ceiling and around to your kit. Build a cyclone which will catch most of the dust but get the round top one.
    Cyclone available in uk .it's a dust deputy knock off.
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/183699497314
    Loads of videos on YouTube covering this cyclone and running waste pipe around.
    You can heat up waste pipe to make fitting bigger so it fits tools
    KIAB likes this.
  3. KIAB
    KIAB Super Member
    Some dust extractors use large bore hose & fittings,so you could use 50mm waste pipe or 68mm down pipe & reduce down to /40mm/32mm,etc.
    Dust Hose Blast Gates I got mine from Rutlands.
  4. mr moose
    mr moose Screwfix Select
    Alternatively, get a powerful vac which collects fine dust particles (most major brands such as Dewalt, Festool etc. use the same filters as there M-class vacs but they just don't have the cut off switch/alarm on them which is a pain in the xxx anyway! ) and add a Thein baffle to collect the majority of dust and shavings to save on bags, you can put the hose on a boom arm so you can access all areas around the shop and mount the whole contraption on wheels. Mine works for all my tools including my planer thicknesser and Circular saw. It is a Dewalt Vac with a 45mm hose.
    KIAB likes this.
  5. KIAB
    KIAB Super Member
    One problem using 68mm dowqn pipe, you may struggle to find a 68mm to 50mm reducer, Hunter have one in their range,could also use flexseal 68mm to 43mm adaptor, otherwise I would stick with 50mm solvent weld waste pipe.
  6. Mark8par
    Mark8par New Member
    Thanks for the replies. I like the idea of the Cyclone attachment but I need some flexibility as I have a few jobs to do that involve sanding indoors, so I want to keep dust to a minimum. Also I have been reading about class l and m vacs but from what I have read, if i pick the right one it would have the same class m filter, it would just be missing an alarm to notify a drop in performance.
    What do you think if i get a class L vac with a cyclone when attached to equipment in the garage and then remove the cyclone when using elsewhere, this would help the filter last longer?
    Which Vac would you recommend, I don't mind paying a little more for something if its worth the money and performs better.
    Thanks
  7. Wayners
    Here is mine. £2 bread box from car boot sale. Cyclone on top with sash window screw locks either end of lid. Draft seal on lid. Mdf I cut to lock on the top of festool like systainers do. Mdf has 4 door stops as feet so offen it will stand on floor with my cheapo shopvac as I don't always take festool to work. I've changed the hose now to pool hose 38mm..I've removed the 40mm pipe as was bit naff[​IMG]
    Here it is now...with pool hose. Bit of tape and fittings fit a treat. Even made new pipe bung to push in vac with 50mm to 40mm waste pipe reducer. It's in this pic below. Plaster dust in box[​IMG]
    mr moose, WillyEckerslike and KIAB like this.
  8. glob@l
    glob@l Active Member
    Looks good!
  9. sospan
    sospan Screwfix Select
    Is that an old paint brush in the box ?
  10. sospan
    If you are mainly using your tools in the garage. I would consider getting a heavy duty chip and dust extractor this one is £149 https://www.rutlands.co.uk/sp+power...p-and-dust-collector-550-watt-rutlands+dk7108
    Tuck this away and run proper ducting to the various work stations £25 - £40 and buy their power tool adaptor sets £25
    What you will find is that some of the tools like the mitre saw have quite rubbish dust extraction even with a powered extraction. One of the best solutions is to make or buy a hood to gather up the chips and dust
    With your £500 budget you can get a very good solution and could even include one of these for £150 which will collect any airborne particles that the machine extractors miss and if you do any hand sanding.
    mr moose likes this.
  11. glob@l
    I don't suppose an extractor fan from an old cooker hood would be powerful enough to adapt in a simular way as the above? Got one lying around doing nothing, just a thaught.
  12. Wayners
    Dead brush. Dried paint on it. Pushed in to show depth
  13. sospan
    Theoretically, it would work and vent it to outside and have the end of the hose in a dustbin
  14. glob@l
    Do you think it will have enough power though?
  15. sospan
    In terms of airflow cubic feet per minute (CFM) a Festool midi cleaner move 140 cfm whilst a low end cooker hood does 200 cfm. Not being an expert on air flow, it seems it could theoretically work
  16. glob@l
    Thanks for that, I may rig something to see what the effect has.
  17. mr moose
    I think it does work because I have two ordinary extractor vans going to outside in the large shed I am renting and I just have them on all the time when working it does feel like it's keeping the air clean of fine particles . Here is a pic of my dust extractor set up (as mentioned earlier in this thread) . PS.I have a wireless switch on the dust extractor so I can plug in my tools at any socket in the workshop and just move the vac hose around to them. 20191002_174104_1135.jpg
    Wayners likes this.
  18. glob@l
    I will also be doing a fair bit of filling and sanding in preperation for painting walls, the dust from the sanding gets everywhere, even if you close the doors and open the windows. Can anyone offer any other solutions with or without the dust extractor? Unless a dust extractor was used regularly it would be difficult to justify the cost involved.
  19. Wayners
    £35 Titan vac but add second hepa vacuum bag (henry I use) slid over the intake spoune inside vac, then fitted to sanders and tools bodged on with duck tape and waste pipe works great. @glob@l
  20. glob@l
    Thanks for the input, not sure what a spoune is, however you say it's where the bag goes over, so, not sure how you get a second bag onto it though?
