My boiler copper pipes are 15ml. Can I get a modern boiler to fit these?
Discussion in 'Plumbers' Talk' started by Robin Bailey, Oct 12, 2021.
  1. exbg
    exbg Active Member
    Just to clarify for the benefit of other DIYers types - there are 15mm gas supply boilers, but not combis, especially 35Kw ones. If the water performance of the existing boiler is good, then there has to be some 22mm hidden away.
  2. exbg
    exbg Active Member
    How good is your hot water, currently?
  3. Robin Bailey
    Robin Bailey New Member
    It's pretty good. Blasting out. Makes me think there has to be 22mm in there somewhere.
    exbg likes this.
  4. Robin Bailey
  5. Robin Bailey
    Any ideas of what this part is?
  6. jonathanc
    jonathanc Screwfix Select
    Flue duct front assembly part no 0020020718
    about 25 to 30 quid
    I really can’t see the point of spending nearly 5000 quid to replace a working boiler because of a minor leak on a cheap part. Your service engineer will know this is cheap part and very likely an easy fit
  7. Robin Bailey
    Boiler is nearly 10yrs old. Like you said 'If it isn't broke why fix it?'.
    So about £100+ to fit it plus labour & VAT?
  8. jonathanc
    Just clean it up and see where it is leaking from. Post up a close up pic. I suspect it is a moulding point in the plastic and a quick blob of fireproof silicone will fix it.
    definitely not a new boiler….
  9. exbg
    exbg Active Member
    I guess you are glad that you posted originally ?
  10. Robin Bailey
    Good to get confirmation on here. This boiler business is not cheap!
    exbg likes this.
