My tiles are falling off
Discussion in 'Tilers' Talk' started by Lydia84, Jan 13, 2021 at 9:14 PM.
  1. Lydia84
    Lydia84 Member
    Anyone know best why to fix this above my window and why it’s happened? Thanks
  2. nigel willson
    nigel willson Screwfix Select
    Lack of adhesion between wall and tile adhesive . Or they tiled onto painted surface. How long have they been there
  3. Lydia84
    Lydia84 Member
    Probably since the mid to late 90s by the looks of the pattern on the tiles around the border which is like a 90s mosaic, can I fix myself, seems to be getting worse and spreading across the window due to the weight pulling them down
  4. Jord86
    Jord86 Screwfix Select
    They need to be carefully removed and the wall checked for any damp ingress or cracks.
  5. nigel willson
    Take them down carefully. If wall surface is ok them refit with new tile adhesive. You need to make up a temp support whilst the tiles are setting. Would suggest a cross piece of timber under the tiles and supported by a few other bits
