My Windows is stuck.
Discussion in 'Tech Talk' started by Deleted member 33931, Nov 21, 2017.
  1. Win 10 - the wee window logo in the bottom-left doesn't launch the menu as it did.
    Nothing happens. Any ideas, please?
    (A right-click on it brings up the menu with 'Progs and features', 'Power options' etc etc, but not the usual Program/App etc menu.)
  2. CGN
    CGN Well-Known Member
    Prob down to moisture causing swelling of the main frame. A good thwack with a hammer and crowbar should sort it :rolleyes:
  3. 'Restarted' and it's ok again.
    Phew - puts crowbar down...
  4. KIAB
    KIAB Well-Known Member
    A right pane!
  5. Dr Bodgit
    Dr Bodgit Well-Known Member
    I suspect its due to too much window licking.
  6. snappyfish
    snappyfish Active Member
    Or maybe he left some tape around the windows to long after painting :p
    Dr Bodgit likes this.
  7. snappyfish
    If it does it again it try making sure your windows is fully updated. If it comes back again do a scan file system.
    Pressing CTRL+SHIFT+ESC
    At top of next window you should see File>Run new task click this then in new create new task box type CMD
    A new window will now appear with a cursor flashing next to c: \windows\system32>
    Type in the following command;
    sfc /scannow
    and press enter.
    Windows will now run a scan on your file system and let you know whether it discovers any discrepancies.
    Deleted member 33931 and KIAB like this.
  8. KIAB
    It's a very useful command to know,one I use it a lot.:)
    Several others worth knowing as well.
    snappyfish likes this.
  9. Isitreally
    Isitreally Well-Known Member
    Bloody Brexit. :D:D:D:D
  10. masterdiy
    masterdiy Active Member
    Just pay more, your worth it.
  11. joinerjohn1
    joinerjohn1 Screwfix Select
    Just a shame you managed to fix it DA, then we wouldn't have to listen to your eternal Remoaning. :D:D:D:D
  12. Isitreally
    DA, Mr L'oreal. :D:D:D
    Deleted member 33931 likes this.
  13. kitfit1
    kitfit1 Well-Known Member
    Mmmmmm, pressing CTRL-ALT-DELETE after clicking on your OS hardrive used to be a very interesting one lol :D
  14. CGN
    The 3 finger salute!
    KIAB likes this.
  15. kitfit1
    Yep, used to sort everything with WIN98 up to and including WIN7 lol :D
    KIAB and CGN like this.
