Mystery holes in walls
Discussion in 'Engineers' Talk' started by Kindy, Jun 7, 2021.
  1. Kindy
    Kindy New Member
    Hello, my parents house has some weird holes appeared above the skirting boards. I can't seem to attach a picture. The holes are about golf ball size and like a bullet has been fired through. They are along one internal wall which goes through the middle of the house. The holes are about 1.5m apart and also appear on both sides of the wall. It continues past a doorway as well. Can anyone advise what this is? There is a vertical crack in one bedroom above this said wall. The house is a main road and upstairs shakes as lorries go by. Thanks in advance.
  2. I-Man
    I-Man Screwfix Select
    Not sure how you expect a response without us seeing a picture
  3. stevie22
    stevie22 Screwfix Select
    Has the house suffered subsidence and been underpinned? Could be remains of needles but rather small.
    Could also conceivably be some form of damp treatment but that would generally be the external walls.
  4. DaveF
    DaveF Active Member
    That's strange. How many holes are there?
  5. Kindy
    Kindy New Member
  6. Kindy
    Kindy New Member
    Hiya, posted pics below. Not sure why the second one repeated several times.
  7. Kindy
    Kindy New Member
    There are 2 on the hallway side of the wall. And also on the living room side. Also one past the door - both sides as well.
  8. Kindy
    Kindy New Member
    It hasn't been underpinned. There is a crack in the room upstairs above the wall. Hopefully image attached. Not sure of that would be subsidence. Crack.jpg
  9. I-Man
    Remove the plaster where it's cracking to get a better look at what's there
  10. Kindy
    Kindy New Member
    Thanks. Will try that.
  11. koolpc
    koolpc Screwfix Select
    Mice have jackhammers?
  12. I-Man
    possibly nail/screw pops?
  13. Astramax
    Astramax Super Member
    Missing Peruvian miners finally found!
  14. CGN
    CGN Screwfix Select
    The crack is nothing to worry about by looks of it. As for the ‘holes’, just take plaster off to get a better look...will need filling back in anyway.
    perhaps central heating pipes used to go through and just not filled in properly.
  15. Bob Rathbone
    Bob Rathbone Screwfix Select
    Has anything been fixed to the other side of the wall, a new skirting board perhaps, could be the fixings poking through.
    Astramax likes this.
  16. Astramax
    Whatever is fixed on the otherside of the wall is causing the problem as mentioned in the above post. The bulges are caused from a pushing action as indicated by the cracks.
    TangerineDream likes this.
  17. Rulland
    Rulland Screwfix Select
    How old is the house?, the skirting looks very shallow, and zooming in on the first picture it doesn't look like plasterboard to me-colour wise.
    I have seen skirting this sort of size used on asbestos boards, maybe others here may have an opinion.
