mystery switch with fuse and light in my cupboard
Discussion in 'Electricians' Talk' started by Kostas, Oct 11, 2019.
  1. Kostas
    Kostas New Member
    Hi,
    I've this switch in my cupboard and I don't have a clue what it does. Does anyone know? There isn't any obvious usage for it, there is no other plug in the cupboard or any device. There is no machine that can use it at the nearby bathroom or room.
    Thanks,
    Kostas
  2. Tony Goddard
    Tony Goddard Well-Known Member
    The fitting is a Fused Connection Unit (FCU) or old term a fused spur. this one is an FCU switched with neon to be correct. They are used to switch fixed apparatus such as (but not limited to) heaters, electric towel rails, immersion heaters, central heating boilers etc etc..
    Carefully undo the screws (with mains off at fuse box) and pull the plate forward, you will see terminals marked L In/Line, N In/Line, these will have wires in, then their will be terminals marked L Out/Load, N Out/Load, if these have wires something connects to it, if not then it is not feeding anything.
    Look at your consumer unit/fuse box, switch off the breakers one by one until the red light goes off - what is written on the label of that breaker?
  3. Kostas
    Kostas New Member
    Tried the switches of the breaker, it went off when i turned off the "bow ring". But so did my tv.
  4. Bazza
    Bazza Screwfix Select
    It’s on a ring final circuit then, but it may not even be in use. Have you done as Tony asked, are there any wires on the load terminals of the FCU?
    Turn that breaker off first do it’s not powered if you unscrew it.
  5. Tony Goddard
    Looking at that cupboard, was it ever an airing cupboard with a tank in it?
  6. peter palmer
    peter palmer Super Member
    It might not do anything, turn off power, unscrew the front and take a picture, could be for an optional extra like an alarm panel or towel radiator.
  7. Bogle Crag
    Bogle Crag Active Member
    Some properties built under NHBC specs had provision for heaters in cupboards back in the 80s
