Need advice RE installing RSJ in supporting wall
Discussion in 'Builders' Talk' started by Monkey Chops, Aug 10, 2018 at 2:13 PM.
  1. Monkey Chops
    Monkey Chops Member
    Afternoon! I'm looking to get someone in to fit an RSJ so we can remove a supporting wall and make two rooms into one. The supporting wall also has a chimney in it on one side, which I will be removing, there is also a much smaller chimney upstairs, which, again, I'll remove before they start. The chimney is already removed from the roof and loft.
    So the job is just to install the RSJ the full width of the room (3.5m or as near as possible) and make safe so I can remove the wall below it. The rooms are 3.5m wide.
    How much should I be looking to pay for someone to do this? I'm in the NW of England.
    Cheers :)
