Typically I will always use celotex in every in job where insulation is required but when it comes to complex roofs with lots of different angles it can be time consuming to get a perfect fit. So I'm always looking at ways to do a better job when I can across icynene on a trade show. I keep hearing mixed things about the product and I won't use it till I'm confident. However every single construction programme I see where the building takes place in America and Canada they always use spray foam insulation and they don't seem to be having problems with rot (which seems to be the main issue) and yet they don't use hardly any pressure treated timber and 90% of homes are timber frames over there and this is using closed cell insulation as apposed to open cell.
