As my previous thread where i was trying to trace and test wiring that can be used for an outdoor light. I traced it back to where it once was before being cut and disconnected. My question is i want to make the fused spur live again. But there is no markings to indicate which wire is the switched live i am assuming its going to be the single red cable and the two in middle are perm lives with the last branching off to another loop? Problem is i don't think there is space for any neutral wires in the block so i'd need to determine which i can use from the neutral and live again to get the fused spur back up and running. Thanks
