I have a Neff dishwasher but has some anti flood thing fitted, what connector do I need to go onto normal 15mm pipe? Image attached
Will fit the normal washing machine valve. That anti flood valve will turn flow of water off,if flow is above a certian amount.
Just the usual washing machine valve, such as; https://www.screwfix.com/p/washing-machine-valve-without-check-valve-15mm-x/51231
OK thanks just like https://www.screwfix.com/p/washing-machine-valve-with-check-valve-15mm-x/27660#_=p
Yes but ....... Make sure you fit the blue handle (also supplied) It won’t work with the red handle fitted as in the link as it uses cold feed (I’m joking really) ..... but fit the blue handle ...... really
In actual fact KIAB, a check valve is not a good idea because the machine itself already has a check valve built in. All another valve will do is reduce the flow rate, which is not a good thing to do.
