Nervous in Newcastle: could this be lead paint?
Discussion in 'Painters' Talk' started by bubbagump, Jun 26, 2021.
  1. bubbagump
    bubbagump New Member
    Hi all :)
    Having just bought our first home I'm v new to this whole DIY thing so apologies if these Qs are daft.
    Started painting my landing the other day and long story short it bubbled - clearly there was wallpaper underneath. The first few strips (under where I'd painted) came off dead easy, but the rest of it has been a chore. My partner and I set about it yesterday - we have masks and goggles but we took the masks off after a bit as it was sweltering and it wasn't too dusty. Underneath the paper there are a couple layers of paint, and some mostly ok plaster. We bought a wallpaper steamer but it was broken, so we were just using elbow grease and metal strippers.
    We've managed to get a couple bits up (smaller patches pictured, larger patches came off more easily downstairs), but as I was falling asleep last night I had the horrid thought it could be lead paint under the paper. I've ordered a testing kit which is coming soon (hopefully today).
    The house was built in 1912 - I know the majority of houses built in the first half of the 20thc are basically guaranteed to have *some* lead paint, however I'm now freaking out I've poisoned my partner and our cats. If the test is positive, do I have to get us tested, or will the exposure be minimal?
    Also, is there a safe way to remove the wallpaper if the paint underneath is lead? When we get a working steamer, will this be safe to use on it? Or should we just cut our losses and get some pros in?
    Thanks in advance!
  2. teabreak
    teabreak Screwfix Select
    Very unusual to find lead paint on a wall, lead is mostly gloss or undercoat on woodwork. Normally water based on walls very often old wall paint pre 1950 is distemper if so a steamer will shift it as will scrubbing with sugar soap, a nasty messy job. if it is not at all chalky chances are it is just emulsion not a worry but very hard to strip as it soaks in to the plaster.
    bubbagump likes this.
  3. bubbagump
    Thanks @teabreak :) that's really reassuring!
    teabreak likes this.
