Why do experience sparkx hate it????????? I had a dance, with one today, who said when he taught the neutral should be switched, if you take it to the switch?????????? Thoughts experience sparkx????????
block in the way???????? ------------------- If there's no room for a single connector block the backbox is prob too small anyway!
Sill,AND OTHERS,YOU can put in a 35mm back box, and do a 2nd fix, wither a dimmer, and struggle with a block???????
here sparkless what happens in these f ers then when theres a few phases floppin about http://www.tlc-direct.co.uk/Images/Products/size3/MKK3514.JPG *** wtf fncoc cheers
SILL, YOU STUPID BOY OR DO BE???????????? nahhhhhhhhhhhh! Fit a dimmer switch on an existing dance, with the dance wired, a loop in loop out method?????? IE, three cables at switch????? The prob????????????? No space for neutral termination??????????
