New bib taps not working
Discussion in 'Plumbers' Talk' started by Kate Roberts, Nov 8, 2019.
  1. Kate Roberts
    Kate Roberts New Member
    just replaced two bib taps outside with new brass bib taps onto 25mm pipe.
    Neither are working since turning water back on, any ideas?
    If it was just one id think it’s maybe a faulty tap...but both of them?
    Any ideas before I replace both taps tomorrow gratefully received!
  2. terrymac
    terrymac Screwfix Select
    Did you isolate the supply by turning off a gate valve , that has a big red ,round wheel head ?
  3. Kate Roberts
    I just turned the stop tap off before replacing them.
    Turned it back on but now nothing coming out of either tap...
  4. terrymac
    Does the stopcock isolate other tap outlets ,which work OK. Or does it only isolate the two bib taps ?
    Kate Roberts likes this.
  5. Kate Roberts
    It’s the main (and only) stop tap
  6. nigel willson
    nigel willson Screwfix Select
    Have you used PTFE tape, have you taped over the inlet side of the valve
  7. ecoplumbing
    ecoplumbing Active Member
    Are the taps fixed onto a backplate? Take the taps off, turn the water back on. If water comes out you know the problem is with the taps
  8. Kate Roberts
    Yes used ptfe tape but only on the threads, not covering the inlets
