New Drain Line into existing manhole
Discussion in 'Plumbers' Talk' started by qamikazi123, Nov 16, 2019.
  1. Jitender
    Jitender Screwfix Select
    That's going to be so much easier and makes a lot of sense, wasn't too fond of your first plan:(, just have to take up more of that slab.
    The RW clay pip is running parallel to the building, so makes sense. If you trace it back can you locate the beginning point, i.e a RW down pipe.
    Just seeing where its easier to replace that section in plastic or having to 'T' into existing run.
    Would you need a rodding point or would the be happy with an access boss at the bottom of the stack?
    If former then you will essentially have to 'T' in twice.
    [​IMG]
    qamikazi123 likes this.
  2. stevie22
    stevie22 Screwfix Select
    Shared pipe = water authority consent to alter. Amazed BC haven't flagged this.
  3. qamikazi123
    qamikazi123 Member
    The pipe being altered is not WA. It is a rainwater drain pipe that was installed over 25 years ago during an extension by previous owner and connects into the main sewer. All i am doing is T'ing into the roof water drain already there. Its a pvc pipe. WA pipes are the old clay ones. Not touching them
