New flue new boiler
Discussion in 'Engineers' Talk' started by James Semaj, Mar 21, 2021.
  1. James Semaj
    James Semaj New Member
    If I knew that a new boiler comes with a new flue, I would probably think twice before replacing my old one.
    Could you please have a look at the pictures at tell me whether or not it's done correctly. Is the flue waterproof/watertight? I've indicated places on it which worry me most...
  2. Mike83
    Mike83 Screwfix Select
    Wouldn’t worry about the top 2 issues. That’s just the flue design.
    Not sure about the bottom issue though.
    That usually has a tapered out section that fits over the plastic shroud.
    Could probably give a better answer if we could see it from the side.
    James Semaj likes this.
  3. jonathanc
    jonathanc Guest
    Would you buy a new car and fit it to your old exhaust pipe? New boiler and new flue is obvious I would have thought.
    anyway I don’t think daylight should be visible through there. What make and model of boiler have you had?
  4. James Semaj
    Ideal replaced with Worcester.
  5. Mike83
    They’ve maybe used the old flashing so it could be ill fitting.
    You can see daylight with some setups even when fitted correctly.
    James Semaj and jonathanc like this.
  6. jonathanc
    jonathanc Guest
    i think it needs a new flashing kit. No idea where there are a couple of bends in it either
  7. Mike83
    41A413E6-4D38-4C8D-A830-BE911228E2D8.jpeg The flue is actually straight.
    The collar and flashing provide support.
    It just looks like a bend.
  8. jonathanc
    jonathanc Guest
    Ok I stand corrected!
  9. Mike83
    Usually the flared out part (red arrow) should fit over the collar (blue arrow).
  10. James Semaj
    That's what I suspected. It looks like there is something missing or the top part doesn't go all the way in the bottom one. Which must've resulted in a gap (daylight can be seen from the inside). This was just filled with transparent silicone.... But I don't think it will last long.
    Just another job (not) well done. Why does it even surprise me....:(
  11. Mike83
    Maybe the flashing was suited to the ideal vertical flue and not the Worcester.
    Each manufacturer has their own version that works perfectly with their terminal.
    You also get standard flashings that work with most flues but something just doesn’t look right with that flue.
  12. jonathanc
    jonathanc Guest
    Well clear silicone is a bodge. Get them back to do it right
  13. James Semaj
    I just thought it's like replacing a gas fireplace, silly me...
