New front extension 1970s design
Discussion in 'Builders' Talk' started by RichMu, Feb 11, 2024.
  1. RichMu
    RichMu New Member
    Hi All.
    We are in the process of buying this house and need to plan our renovations now so we can begin on them soon after completion. We would like to extend the lower ground floor on the right side in line with the garage which would extend the kitchen. Then somehow add a pitched roof to the entire ground floor front end.
    Really keen to understand the work involved and estimated costs...guessing a steel would be needed and footings dug. Would I need planning permission?
    Any help, advice or other ideas welcome please. I've attached the current front picture and floor plan to help understand the property better.
    Thanks in advance.
  2. BuildingMad
    BuildingMad Well-Known Member
    Budget £30k building work, excluding kitchen installation.
    You could just remove the wall below the kitchen window & lose or hide most of the remaining side walls within the row of kitchen floor units, or full height larder units. Saves on lintol work.
    Planning department should be approached for their assessment, but building regulations will be required.
    The staircase window needs consideration with a pitched roof.
    However you could have a dummy pitched roof all round with a flat roof behind, ensuring water can get out.
    RichMu and Severntrent like this.
  3. RichMu
    RichMu New Member
    Thanks for your comment and suggestion.
    Do you think just adding a pitched roof above the kitchen extension and porch would look and work OK? Leaving the flat roof over the rest? Saves me changing the large window.
    Or you think leveling up the windows would look better...
  4. BuildingMad
    A dummy pitch to the whole front elevation with a flat roof behind would smarten things up.
    With the eaves overhang it sits mainly on the external wall.
    [​IMG]
    RichMu likes this.
  5. RichMu
    RichMu New Member
    Looks good. Not sure what the dummy pitch is? Does that mean it's flat roof on top of that
  6. stevie22
    stevie22 Screwfix Select
    Going forwards is definitely a planning permission job and as a rule not often given.
    You maybe want to come up with a plan B.
  7. BuildingMad
    [​IMG]
    RichMu likes this.
  8. RichMu
    RichMu New Member
    Thanks again for the picture reference on roofing.
    I'm guessing if I were to leave the large window it would need to be a very shallow pitch.
  9. RichMu
    RichMu New Member
    But the neighbour has brought their whole property forward. The land is my own so I don't understand why it wouldn't be allowed
  10. stevie22
    Because the law is that you have to get permission from the local authority before you extend your property unless that extension falls within the limits set out for Permitted Development AND your property has those rights (not all do).
    The fact that your neighbour has done something similar does not automatically mean you will be allowed to do so as, unlike UK law in general, planning does not follow the rule of precedence. That said it does realistically increase your chances of approval but the only way to know for sure is to put in an application. Even if you went for pre-application advice (not all authorities do this) it wont be binding.
  11. RichMu
    RichMu New Member
    Could someone please tell me if this type of roof set up is possible on the ground floor if I am able to extend the front on the right side?
    Also what is the type of roof call please?
    Thanks
  12. billysloke
    billysloke Active Member
    IMO what the neighbour has done warrants an ASBO
    RichMu likes this.
  13. BuildingMad
    Yes it's possible.
    It encompasses most names for a roof depending on the angle you are looking at it from & where the slopes are.
    Pitched, hipped, gable, etc.
    RichMu likes this.
  14. RichMu
    RichMu New Member
    Thank you. Do you think this could be a good idea or do you have any other suggestions for this set up perhaps?
  15. BuildingMad
    Looks fine.
